Islaam Posted January 5, 2011 Share Posted January 5, 2011 Was ist das was oben in der Titelleiste steht? Wa Salam Quote Link to comment Share on other sites More sharing options...
Islaam Posted January 5, 2011 Author Share Posted January 5, 2011 *push* weist es niemand`? Wa Salam Quote Link to comment Share on other sites More sharing options...
Webmaster Posted January 5, 2011 Share Posted January 5, 2011 Das sind deine Punkte. Quote Link to comment Share on other sites More sharing options...
Islaam Posted January 5, 2011 Author Share Posted January 5, 2011 @Webmaster Ja wozu dienen sie? Wie kriegt man sie? Wa Salam Quote Link to comment Share on other sites More sharing options...
Webmaster Posted January 6, 2011 Share Posted January 6, 2011 Wenn deine Beiträge bewertet werden von anderen Usern, bekommt du Punkte. 1 Quote Link to comment Share on other sites More sharing options...
Islaam Posted January 6, 2011 Author Share Posted January 6, 2011 Oh Cool bewertet mich Wa Salam 2 Quote Link to comment Share on other sites More sharing options...
Webmaster Posted January 6, 2011 Share Posted January 6, 2011 hab ich Quote Link to comment Share on other sites More sharing options...
Islaam Posted January 6, 2011 Author Share Posted January 6, 2011 Dankeschööööön, hab dich aber vorher Bewertet Quote Link to comment Share on other sites More sharing options...
Webmaster Posted January 6, 2011 Share Posted January 6, 2011 oh danke dir Quote Link to comment Share on other sites More sharing options...
Jörg Posted January 7, 2011 Share Posted January 7, 2011 Wie werden die bewertet? Habe gerade eine Wertung abgegeben und diese erscheint nicht. Also bei zehn Bewertungen erscheint beim User ein Punkt? Oder nach Konfession, nur Muslime können bewerten oder bewertet werden. 2 Quote Link to comment Share on other sites More sharing options...
Webmaster Posted January 7, 2011 Share Posted January 7, 2011 Genau, nur Muslime bekommen Punkte )) ehrlich gesagt, weiß ich nicht, wie das mit der Bewertung funktioniert. Ich schalte mal System Admin Levent ein. Quote Link to comment Share on other sites More sharing options...
Levent Posted January 7, 2011 Share Posted January 7, 2011 Hallo liebe Freunde, Das ist so, dass die Bewertung eines Users mit einem höheren Renommee Faktor mehr zählt, als von jemandem mit einem niedrigem. Hier ist eine gute FAQ zum Rennomee System: http://forum.zwai.net/faq.php?faq=renomee_faq Was ist das Renommee-System? Im Forum ist ein Renommee-System aktiviert, das Auskunft über den Ruf des Benutzers im Forum gibt. Das Renommee wird am rechten Rand der Titelzeile jeden Beitrages und im Benutzerprofil durch diese 'Lampe' angezeigt. Das Renommee-System soll neuen oder selten im Forum anwesenden Benutzern eine Orientierung bieten, wie sich der jeweilige Benutzer bisher im Forum verhalten hat, bzw. wie nützlich dessen Beiträge von den anderen Benutzern empfunden wurden. Wie kann ich erfahren, wie das Renommee eines Benutzers im Forum ist? Je nach Anzahl der Renommee-Punkte eines Nutzers hat das Symbol verschiedene Farben: sehr positives Renommee: positives Renommee: ausgeglichenes Renommee: negatives Renommee: sehr negatives Renommee: Wenn Sie innerhalb eines Profils oder Beitrages mit der Maus auf das Symbol zeigen, erscheint eine dem Renomme-Wert zugeordnete Beschreibung, die Ihnen Auskunft über den Ruf des Benutzers gibt. Benutzer können ihr Renommee im Forum generell nicht verstecken. Wie kommt der Renommee-Wert zustande? Bei der Registrierung ist der Renommee-Wert jeden Nutzers zunächst auf 0 gesetzt. In dem zusätzlichen Text erscheint dann die dazugehörige Beschreibung 'Benutzername ist noch ein unbeschriebenes Blatt'. Die Renommee-Wert verändert sich durch die Bewertungen anderer Benutzer. Dabei hat die Bewertung durch Benutzer mit einem hohen Renommee-Wert oder durch einen Administrator einen anderen Einfluss auf den Renommee-Wert als eine Bewertung durch einen Benutzer mit niedrigem Renommee-Wert. Folgende Faktoren bestimmen dabei, wieviele Renommee-Punkte ein Benutzer mit einer Bewertung abgibt: Beitrags-Faktor: bei einer bestimmten Anzahl von Beiträgen ändert eine Bewertung den Renommee-Wert des Autors um einen zusätzlichen Punkt. Registrierungs-Faktor: bei einer bestimmten Anzahl von Tagen, die der Benutzer registriert ist, ändert eine Bewertung den Renommee-Wert des Autors um einen zusätzlichen Punkt Renommee-Punkte-Faktor: bei einer bestimmten Anzahl von Renommee-Punkten ändert eine Bewertung den Renommee-Wert des Autors um einen zusätzlichen Punkt. Bewertungen von Benutzern mit einem Renommee-Wert von 0 oder kleiner 0 fliessen nicht in das Renommee des bewerteten Benutzers ein. Wie kann ich erfahren, wie mein Renommee im Forum ist? Auf der Startseite des Benutzerkontrollzentrums sehen Sie letzen 20 Beiträge von Ihnen, die von anderen Benutzern bewertet wurden sowie das Datum und den evtl. abgegebenen Bewertungskommentar. In der Titelzeile werden rechts Ihre Renommee-Punkte angezeigt. Wenn Sie auf das -Symbol in einem Ihrer Beiträge klicken, wird Ihr Wert ebenfalls angezeigt. Andere Benutzer sehen jedoch nur den Beschreibungstext, der Ihrem Renommee-Wert zugeordnet ist. Die Skala reicht von -150 bis 2000 Renommee-Punkten. Der den Renomme-Status beschreibende Text (z.B. 'Benutzername ist noch ein unbeschriebenes Blatt' etc.) ist in 15 Stufen unterteilt. Wie kann ich das Renommee eines anderen Nutzers beeinflussen? Indem Sie einen Beitrag eines Benutzers bewerten. Dies geschieht über das -Symbol in der Titelzeile neben dem Benutzernamen. Wenn Sie auf dieses Symbol klicken, öffnet sich ein Fenster, in dem Sie angeben können, ob Sie dem Beitrag zustimmen oder nicht zustimmen. Zusätzlich können Sie einen kurzen Begründungstext angeben. Dem bewerteten Nutzer wird anschliessend im Benutzerkontrollzentrum die Bewertung (positiv oder negativ, das Datum und der evtl. Kommentar angezeigt. Nach der Registrierung können Sie zunächst nur positive Bewertungen abgeben. Negative Bewertungen können nur von sog. "Stamm-Nutzern" abgegeben werden, die selbst mehr als 100 Renommee-Punkte haben. Egal wie Sie abstimmen: bewerten Sie fair! Sie sollten nicht Kriterien wie Rechtschreibung oder die persönliche Meinung des Benutzers zu Grunde legen, sondern vielmehr, wie hilfreich oder konstruktiv Sie den Beitrag für die Diskussion empfinden. Unterschiedliche Meinungen sind ja gerade das Interessante und Wertvolle in einem Diskussionsforum und sollen kein Bewertungskriterium darstellen! Nachdem Sie Ihre Bewertung abgesendet haben, schliesst sich das Bewertungsfenster automatisch. Ein Beitrag kann nur einmal von jedem Benutzer bewertet werden. Eigene Beiträge können nicht bewertet werden. Sie können den gleichen Nutzer nicht mehrmals hintereinander bewerten, auch wenn Sie verschiedene Beiträge des Benutzers bewerten wollen. Sie müssen erst eine bestimmte Anzahl anderer Benutzer bewertet haben, bevor Sie den gleichen Nutzer erneut bewerten können. Innerhalb von 24 Stunden können Sie höchstens 10 Bewertungen abgeben. Wie soll das Renommee-System benutzt werden? Fair und überlegt! In erster Linie soll die 'Selbstkontrolle' der Benutzer untereinander gefördert werden, wovon wiederum die ganze Community profitiert. Nutzen Sie das Renommee-System verantwortungsvoll und sehen Sie es als Chance und nicht als Hemmnis. Wir glauben an das Gute in unseren Benutzern und gehen davon aus, dass sich alle Benutzer fair verhalten. Wie darf das Renommee-System nicht benutzt werden? Es ist verboten, unter Benutzung mehrerer eigener Benutzernamen Bewertungen für sich selbst abzugeben. Alle Bewertungen sowie die dazugehörigen IP-Adressen werden protokolliert. Es ist verboten, mit einer Negativbewertung zu drohen, um andere Mitglieder zu einer bestimmten Handlung zu zwingen. Es ist ferner verboten, andere Mitglieder zu bedrohen, damit sie eine positive Bewertung abgeben ("Bewertungserpressung"). Es ist verboten, erhaltene negative Bewertungen mit einer negativen Bewertung eines wahllosen Beitrages des zuerst bewertenden Nutzers zu beantworten ("Rachebewertung"). Es ist verboten, mit anderen eigenen Benutzernamen oder mit Hilfe anderer Benutzer, mehrere negative Bewertungen für ein Mitglied abzugeben, ("Bewertungsbombardierung"). Hilfe! Ich bin ungerecht bewertet worden! Was kann ich tun? Wenn Sie sich durch die Bewertungen anderer Benutzer ungerecht behandelt fühlen, wenden Sie sich bitte an uns! Benutzen Sie dazu einfach den Kontakt-Button in der unteren Leiste. Alle Zeitangaben in WEZ +1. Es ist jetzt 15:29 Uhr. Kontakt - zwai.net - Archiv - Nach oben Quelle: http://forum.zwai.net/faq.php?faq=renomee_faq 2 Quote Link to comment Share on other sites More sharing options...
Webmaster Posted January 7, 2011 Share Posted January 7, 2011 Quote Link to comment Share on other sites More sharing options...
Islaam Posted January 7, 2011 Author Share Posted January 7, 2011 Zu erst Danke! Und zum Thema Drohung. "Ey alta Bewerte mich positiv!" :D 1 Quote Link to comment Share on other sites More sharing options...
